I have a problem with acknowledging alarm from a Remote UI project. When I try to do it from server where the original project is running, ack works normally, but when I try to do it from remote project, nothing happens.
I am acknowledging alarm by setting the property ":_alert_hdl.._ack" to true.
Nedžad
Can\'t ack alarm from Remote UI project
Re: Can\'t ack alarm from Remote UI project
Are you using a dpSet() or alertSet() to acknowledge the alert?
Which value is set for the attribute _alert_hdl.._ack?
Can you please have a look if a log message is written on the client/server when trying to acknowledge the alert.
Probably you have to use getLastError() in your script to detect if an error occured.
