Change resolution of screen
MIRC
Post by MIRC »
I need to change resolution of screen. I have 1920 x 1080 resolution in a UI and another screen is using other resolution, 1280 x 800.
Do I need to remake all panels or there is exist other way?
Thank in advance.
Re: Change resolution of screen
You can open panels designed for a resolution of 1920x1080 on a computer using a smaller resolution.
In the modules you will then get scrollbars.
If you want to display them without scrollbars you can use the config entry initialZoomFactor in the [ui] section.
