I'm having a problem with starting S7Plus Driver in Console, when I try to start it I got the following message:
WCCOAs7plus.exe - System Error
The code execution cannot proceed because s7epaapi64x.dll was not found. Reinstalling the program may fix the problem.
I found this .dll file located in C:\\Program Files\\Common Files\\Siemens\\Automation\\Simatic OAM\\bin folder. Should it be in some other folder or this problem is related with something else?
I am using branded WinCCOA package.
Best Regards,
Nedžad
Can\'t start S7Plus Driver
- mkerk
Re: Can\'t start S7Plus Driver
which WinCC OA 3.15 Patch are you using?
Please try with the latest one (P009), which is available on our portal, if this will solve the problem.
BR,
Mousser
BR,
Mousser
