Problem with curveValues
sergey.gromov
Post by sergey.gromov »
Hello, all.
I want to set 3 arrays of values to trend. Each array contains 25000 values.
[spoiler]
main()
   //values for set to trend
   dyn_time  tt;
   dyn_float ff;
   dyn_bit64 bb;
   const int TR_COUNT  = 25000;  //dynlen values block
   const int TR_COUNT2 = 24999;
   const int TR_CIRCLE = 3;      //number of cycles (blocks)
   int frame = TR_COUNT;
   time tStart = getCurrentTime();
   tStart -= 10;
   for (int blockNumber = 1; blockNumber = (frame-TR_COUNT2); i--)
         dynAppend(tt, tStart-i);
         dynAppend(ff, 10.2*sin(i));
         dynAppend(bb, "1000001100000000000000000000000000000000001100000000000100000001");
      DebugN("Set values to trend", "values block ?" +blockNumber, "dynlen values block:" + dynlen(ff));
      //set data to trend
      TREND1.curveValues("#1_1", ff, tt, bb);
      frame += TR_COUNT;
      TREND1.updatesEnabled(true);
   time tEnd = tStart - 85000;
   setValue("TREND1", "visibleTimeRange", 0, tEnd, tStart+3600);
   //Get values from trend
   dyn_float df;
   dyn_time dt;
   dyn_bit64 db;
   getValue("TREND1","curveValues", "#1_1", df, dt, db);
   DebugN("Get values from trend", "dynlen values:" + dynlen(df));
[/spoiler]
3 arrays of values are formed by clicking on the button (each array contains 25 000 values) and set on the trend widget with the function "curveValues".
The values of the first array are partially displayed on visible time range of trend.
The values of the second and third array of values are outside visible time range of trend.
After setValue() on the trend, the first array is truncated to 20,000 values, and the second and third arrays are set as one point.
Instead of 75000 points that set on the widget, 20002 points are displayed and 55000 points are lost.
Why are values lost when there are more than 20,000 values on a trend?
Re: Problem with curveValues
with which version ?
sergey.gromov
3.14 patch 16
I can not reproduce your problem. See my testpanel attached. https://www.winccoa.com/fileadmin/image ... fTrend.pnl
refTrend.pnl
(2.41 KiB) Downloaded 143 times
sergey.gromov
If set values on visible time range - everything is fine. The problem manifests itself, if I set values that go beyond the displayed time interval.
https://www.winccoa.com/fileadmin/image ... d_test.pnl
trend_test.pnl
(3.1 KiB) Downloaded 132 times
Your problem is this: setValue("TREND1", "visibleTimeRange", 0, tEnd, tStart+3600);
You fill data for today, then you tell the trend to jump back in time. With that, the trend removes values no longer needed (if count > 20000, to reduce memory), since
it assumes it can get the data again when you scroll back to the current time (which in your panel can't be done since you don't have DPs connected, so you would
need to implement the "refill" in the TimeScroll event)
