Adding new clients to Exsiting server with Wincc OA UI.
Chandan
Post by Chandan »
Hi Experts,
We are having server and total number of 6 clients are connected to it.
I can see the details of all the clients from the device management.
In device management it shows as below:-
6/6 UI Connected. 5/5 Unlocked Devices 0/0 Mobile UI Connected
From above and reading the help I understood that six numbers of UI are connected to the server.
I want to add one more client to this server, I installed Wincc OA UI on the desktop, configured it and tried to get connected
to the server. When I open the project Upto authentication it is OK but it does not open the running project.
Instead it gives me message "License Error: Maximum Numbers (6) of allowed instances of manager ui reached"
From the above message it seems to me that the license for UI are only for 6 numbers of clients.Will be highly glad to get the reasons for this.
And how I can be able to increase the number of clients connected to server.
Thanks and regards
Chandan.
Re: Adding new clients to Exsiting server with Wincc OA UI.
If you want to run more than 6 UI clients at the same time you need a license where more than 6 ui clients are defined.
The shield file you cannot change on your own. You have to get in contact with the vendor of the license you are using.
Chandan
Post by Chandan »
Thanks Leopold for the valuable reply.
Regards.
