is there a already implemented way of monitoring a float value and return the average value over time (e.g. average voltage level over a time period of the last 5 minutes)?
Michael Danzer
Monitor float value over time period (average)
- michael.danzer
Re: Monitor float value over time period (average)
Can you please describe more accurate what "monitoring" means.
Do you want to calculate an average value for a given time span or do you want to see values stored in the database?
- michael.danzer
Hi!
Thanks for the reply.
I want to calculate the average value for a given time span. As i recall correctly, the value data will also be stored in an 5 minute database.
Regards
Michael
Regards
Michael
With a statistical datapoint function (config _dp_fct) you can calculate average values for a given timespan.
When an archiving (config _archive) is defined for the same dp element the calculated values can be stored in the database.
For detailed information please have a look the WinCC OA documentation:
Module PARA --> Data point configs --> _archive
Module PARA --> Data point configs --> _dp_fct
