shape.position vs shape.refPoint
chris@blue-catalyst.co.uk
Post by chris@blue-catalyst.co.uk »
I wanted to pick out the position of an object but have found that a getValue on position or refPoint returns only the refPoint even when when different.
I tried this on a rectangle (v3.15p6) where I moved the reference point away from the rectangle, as you can see from the image both the getValue for the position and reference point returned the reference point in both cases.
Is there a way to get the position of an object when the reference point is different?
Thanks,
Chris
michel.eijgermans
Re: shape.position vs shape.refPoint
Post by michel.eijgermans »
Maybe the 'points' property can help you. They are available on a rectangle. It gives you the coordinates of the upperleft and lowerright points when dealing with a rectangle.
The coordinates returned are related to the location on the screen of the object from which they are requested.
