dpQuery using a $dp
AMRPatricio
dpQuery using a $dp
Post by AMRPatricio »
Hi all,
I am trying to use a $dp in one dpQuery. Currently having problems with the syntax.
dpQueryConnectAll("updateStatus",true,"","SELECT '_alert_hdl.._act_state_text' FROM '*.Alarm.unAck.*'WHERE _DP = \\"clifton_50\\" ");
Instead of Clifton_50 I want a $dp.
Any help?
Thanks.
Antonio
nmnogueira
Re: dpQuery using a $dp
Post by nmnogueira »
try
 dpQueryConnectAll("updateStatus",true,"","SELECT '_alert_hdl.._act_state_text' FROM '*.Alarm.unAck.*' WHERE _DP = \\""+$dp+"\\" ");
Instead of defining the datapoint in the WHERE condition you should use it in the FROM statement.
... FROM '" + $dp + ".Alarm.unAck.*' ...
AMRPatricio
Thank you both.
Antonio
