• Page 1 of 1
NFedorenko
web client configuration using different internal and external IPv4 addresses
Postby NFedorenko »
Hello to all
Got a problem:
I need to connect from external LAN using webclient to my system.
But my event and data manager on host use another net.
Is there any special configs i need to check?
When i try co connect at first time,web client see my host and says that device shoud be authorised.
On host in device manager I give a permisson to that machine.
Re: web client configuration using different internal and external IPv4 addresses
Postby NFedorenko »
Some new info about problem.
Web-client can connect to host.
I turned on -dbg HTTP on ctrl manager webclient_http.ctl
I can see http messages on host.
Host send some info to web-client, but when web-client try to connect to data manager causing a problem with connection.
Host is in another domain. All another computers in domain can connect by web-client to target host and everything works good.
But not from another domain.
The most rediculous is that web-client connects to host and download some files and info from host.
