Patch P007 and $DP
adaneau
Patch P007 and $DP
Post by adaneau »
Hi all,
Just upgraded my project to P007 and all of sudden I am encountering a lot of issues regarding $dp in log viewer:
WCCOAui (2), 2018.01.18 12:49:13.754, CTRL, SEVERE, 17/ctrl, Cannot find dollar parameter $iPrecision.
Does someone else encountered similar issues? I mean none of my $DP seems to work as of now. Maybe I am missing some new config entry. I'll try to create a new panel and see if it is working or not.
Alex
mkerk
Re: Patch P007 and $DP
Post by mkerk »
Hello Alexander,
Are you using xml-panel format?. It seems to be the same issue as Forum TOPIC: Dollar parameter replacement broken in v3.15 P007
https://portal.etm.at/index.php?option= ... =7013#7049
BR,
Mousser
mkerk
Post by mkerk »
this problem will be solved with the next patch
adaneau
Post by adaneau »
Thanks Mousser B)
So we can ignore those messages in log intbetween? No others consequences?
renelorenz
Post by renelorenz »
we have aslo encoutered this problem today and run into troubles due to that.
We had to uninstall WCCOA and roll back to P005, since this was the last version we had used without that troubles.
Can you provide information when we can count with this fix (P008)?
Best regards
Rene
It is planned to release patch P008 end of January 2018. With this patch the $-parameter problem will be solved.
