The error message occurred once every day. And the project is restarted automatically.
WinCC OA ver 3.14 OS : Windows Server 2012 R2
The message
WCCILdata (0), 2018.01.18 08:00:22.232, SYS, WARNING, 39, Connection lost, MAN: (SYS: 1 Event -num 0 CONN: 1), Connection reset by peer (10054)
WCCILevent (0), 2018.01.18 08:00:24.138, SYS, WARNING, 39, Connection lost, MAN: (SYS: 1 Data -num 0 CONN: 1), Connection reset by peer (10054)
What is the problem?
On system installed mcaffee security application. Can be reason mcaffee?
Thank you
Connection reset by peer (10054) warning
Re: Connection reset by peer (10054) warning
Does this happen every day around the same time?
Could you also post more messages of the data and event manager from directly before these messages?
- hakan
It is happen every day almost same time.
Not created messages before these messages
- bason4ik
We got the same problem.
Redu system:
peace of log file from side b
WCCILdata (0), 2018.03.10 04:25:33.021, SYS, SEVERE, 63, Connection error, Connection reset by peer (10054)
WCCILdata (0), 2018.03.10 04:25:33.022, SYS, SEVERE, 63, Connection error, Connection reset by peer (10054)
WCCILdata (0), 2018.03.10 04:25:33.023, SYS, SEVERE, 63, Connection error, Connection reset by peer (10054)
WCCILdata (0), 2018.03.10 04:25:33.024, SYS, SEVERE, 63, Connection error, Connection reset by peer (10054)
WCCILdata (0), 2018.03.10 04:25:33.025, SYS, SEVERE, 63, Connection error, Connection reset by peer (10054)
WCCILdata (0), 2018.03.10 04:25:33.025, SYS, SEVERE, 118, Last error already repeated 50 times. Until another output occurs, this one will be blocked.
WINCCOA_SVV14B(1), 2018.03.10 04:25:33.072, SYS, SEVERE, 10/pmon, ?????????? ???????? ???????? WCCILevent(0) ???????! ?????????? ???????(it means Event Manager stops)
peace of log file from side A
WCCILdata (0), 2018.03.10 04:25:33.018, SYS, SEVERE, 63, Connection error, Connection reset by peer (10054)
WCCILdata (0), 2018.03.10 04:25:33.019, SYS, SEVERE, 63, Connection error, Connection reset by peer (10054)
WCCILdata (0), 2018.03.10 04:25:33.020, SYS, SEVERE, 63, Connection error, Connection reset by peer (10054)
WINCCOA_SVV14A(1), 2018.03.10 04:25:33.072, SYS, SEVERE, 10/pmon, ?????????? ???????? ???????? WCCILevent(0) ???????! ?????????? ???????
Redu system:
Only with these few lines of the log files we cannot see what happened in your system.
If you need further information please get in contact with your common WinCC OA support. When submitting a support request please add the logfiles pmon. and PVSS_II.log für both redundant servers.
P.S.: If possible please do not translate the stanard message catalogues which are used for the log messages. If they are translated to Russian analysis by the WinCC OA support be ETM will be more difficult as we cannot read textes in Russian language.
