Got a problem.
When we start webclient_http.ctl GEDI terminates and any UI closes.
Use different numbers in Console.
Use ports https 444 and http 8888.
What could be incorrect?
webclient_http.ctl terminating GEDI
- kilianvp
Re: webclient_http.ctl terminating GEDI
What Version and Patch do you use?
It probably happens in this case by design.
When starting the webclient script a check is made if the connected UIs are defined as valid UIs in the Device Management panel.
If a UI is not defined as valid UI it will be stopped.
Please check the settings in the Device Management panel.
- NFedorenko
I'm using 3.15 P006.
- NFedorenko
Thank you. That helps=).
