recode() has a problom to convert a string to Unicode
lizhigang2017
Post by lizhigang2017 »
Hello, everybody,
I have a problem when I trying to use recode() converting a string to UNICODE encoding string. Unicode encoding will expand a western character with some "\\0" , and for a eastern character will be no problem. The unicode format "\\0" will make WinCC OA string encoding system recgonize as an end of a string.
Problem example:(chinese '??'= hello)
main()
string sUTF8 = "??aaa";
string sGB2312= recode(sUTF8,"UTF8","GB2312"); // correct converted.
blob bGB2312;
blobAppendValue(bGB2312, sGB2312,strlen(sGB2312));
blob bUTF8;
blobAppendValue(bUTF8, sUTF8,strlen(sUTF8));
string sUnicode = recode(sUTF8,"UTF8","unicode"); // incorrect converted.
blob bUnicode;
blobAppendValue(bUnicode, sUnicode,strlen(sUnicode));
DebugN(bUTF8,bGB2312,bUnicode);
Logviewer :
WCCOAui5:[Blob encountered with 9 items, dump follows
WCCOAui5:e4 bd a0 e5 a5 bd 61 61 61
WCCOAui5:][Blob encountered with 7 items, dump follows
WCCOAui5:c4 e3 ba c3 61 61 61
WCCOAui5:ff fe 60 4f 7d 59 61
WCCOAui5:]
WCCOAui5:ff fe 60 4f 7d 59 61 -------> correct target encoding should be WCCOAui5:ff fe 60 4f 7d 59 61 00 61 00 61 00
best regards!
Li Zhigang
Re: recode() has a problom to convert a string to Unicode
Right, that is not possible, since - as you said - strings in WinCC_OA are 0-terminated, so they can only store multibyte encoded strings without 0-bytes.
That is the reason why UTF8 exists - no 0 bytes but all unicode characters can be encoded.
