Hello to all!
There is one thing I (and I guess other developers) B) want to know:
Why 10 000 dpConnect wont affect on event manager as 10 000 _dp_fct config?
How _dp_fct config works? Is it differ from dpConnect?
dpConnect and _dp_fct comparsion
Re: dpConnect and _dp_fct comparsion
A dpConnect() is made by a manager, e.g. CTRL or UI.
The Event Manager has to keep some information which managers have made connects to send the hotlink messages if a dp-element + config + attributes was changed which was used at the dpConnect().
The _dp_fct config is kept in memory of the Event Manager during runtime, resulting in an increased memory usage.
In the Event Manager a _dp_fct (not a stastical dp function) is similar to a dpConnect. If one of the parameters changes the function is called and the result is written to the dp element where the dp function is configured. There is no need to send a message to a manager.
Which of these options is more useful in a given environment and use case depends on the use case.
