Hi all,
What is the best way to check the "ios" count on a running project? In addition to actual I/O (with "_address" config) I also have Dist and DRS connections in the system, so I need to make sure it's all taken into the calculation against my licensed "ios" number.
Licence and \"ios\" count
Re: Licence and \"ios\" count
In the Lab section you will find an example panel which can be used to count the active I/Os.
https://portal.etm.at/index.php?option= ... &Itemid=79
How the results for every system need to be taken into for the license calculation and for the license offer you have to clarify with your WinCC OA sales contact.
- NikolayLevchenko
Thanks, Leopold!
