Good Day all ,
Happy new Year , I have a question regarding the Bacnet objects , If I was using the bacnet engineering explorer and i Generated lets say 10 analog inputs , how would the license counts these objects I/O s . TO explain more each one of these analog objects has a list of bacnet properties such as present value , out of service , priority array , status flags , etc , the question is will the license count each one of theses properties a s a separate I/O so i will get for only one analog input object maybe 16 I/O or the license will consider it as a a single I/O and will discount only one point as it refers to one object .
Regards and best wishes
BACnet Objects
Re: BACnet Objects
For the license all active _address configs are counted.
If a BACnet objects has several properties and all of them have an active _address config it will not be counted as 1 I/O.
The event manager/common driver who is making the license check does not have the information for BACnet objects.
