export and import in the xml
Norrdine
Post by Norrdine »
How do you export and import data in the XML format with WinCC OA?
IBRAHIMALALI
Re: export and import in the xml
Post by IBRAHIMALALI »
Hi ,
You can save panels as xml extension choose the panel you want to export as xml , then open it , save as after that chose the location you want and save as xml .
To import to wincc you can do the same but be sure to use the same xml format as wincc do .
Best wishes
Regards
agruber
Post by agruber »
if the above answer is not what you need take a look at the CtrlXml extension and the functions provided with it. Just search the documentation for ctrlxml.
BR, Andreas
Customer Care
