Can I use SQL (e.g. dpQuery) to determine the number of data points of a datapoint internal type (e.g., _Example)?
Ulrich Ahrens
Post by Ulrich Ahrens »
I would like to determine the created data types of a datapoint type in order to delete them and to create the necessary ones again
Re: Can I use SQL (e.g. dpQuery) to determine the number of data points of a datapoint internal type (e.g., _Example)?
If you want to know which datapoints exist for a datapoint type you can use the function dpNames().
There is no need to use a dpQuery().
