Good evening ,
Do wincc oa supports A KNX Protocol driver , if not Would you suggest a compatible driver that converts KNX to OPC .
Regards
OPC/KNX driver
Re: OPC/KNX driver
In WinCC OA there is no native KNX driver available.
When searching the internet for OPC solutions to connect KNX you will find several possibilities. As far as I know we have not used a KNX OPC connection, therefore we cannot tell you which one of the solutions will work.
Re: OPC/KNX driver
As alternative for OPC you could use a LOGO! with a KNX communication module.
The S7 driver can connect to LOGO!s with TCP/IP.
