Multi Monitor
IBRAHIMALALI
Multi Monitor
Post by IBRAHIMALALI »
Good day all ,
I want to ask about the multi screen configuration , is there a method to open a specific module using ((ChildPanelOnModule function )) on the second screen by default .
Regards
Re: Multi Monitor
If you want to open a new module you have to use the function ModuleOn(). A panel can be loaded inside of the module with the function RootPanelOnModule().
When you want to open a panel and a module at the same time you can use the function ModuleOnWithPanel().
IBRAHIMALALI
Re: Multi Monitor
Hi Leopold ,
ModuleOnWithPanel() ,doesnt have a parameter that you can select from the monitor that you want to display the module on
Regards , you always give great help
Re: Multi Monitor
With the second and third parameter of the function ModuleOnWithPanel() you can define at which position the module shall be opened.
If your desktop covers 2 screens you have to look which coordinate (based on the screen resolution) is the top left corner of the second screen.
