Does anyone know how to get the position of a child panel ?
We are automating testing and I need to figure out where a popup is opened so that I can a separate tool to click on one of the buttons.
I'd need the position of the popup in absolute screen coordinates.
share the fun
Frenk Mulder
How do I get the position of a popup
Re: How do I get the position of a popup
1) you can define the position of the child panel when you open it
2) use the panel attribute windowFrameGeometry or windowGeometry (and then there is also the panel function mapToGlobal)
- fmulder
Thanks. this worked.
Is there also a function to figure what popups are currently open ?
no. You need to know the name, then you can check via isPanelOpen()
- laurensnoorland
Hey all,
The panel attribute windowFrameGeometry does not work correctly under Windows 10 or higher.
This is a QT problem. If i use windowFrameGeometry and windowGeometry i can determine the frame size.
Under Windows 7 this works.
But under Windows 10 the function will return a 8 and 31 instead of 1 and 31 pixels.
Laurens
Laurens
