Runtime error
IBRAHIMALALI
Runtime error
Post by IBRAHIMALALI »
Good day ,
Once opening tools >>> start runtime . The project couldn't start again . I have lately tried many things like using the web client and desktop interface , as well the panel topology editor tool . I think this may affected the project , please help as a I don't have backup points.
This Is the logger error :
WCCOAui (1), 2017.12.07 14:24:20.397, CTRL, SEVERE, 176, Uncaught exception in thread started at main:
WCCOAui (1), 2017.12.07 14:24:20.397, CTRL, SEVERE, 79, Index out of range,
Module: Startup
Panel: C:\\Siemens\\Automation\\WinCC_OA\\3.15\\panels\\vision\\login.pnl []
Object: 1 named: "password" of type: TEXT_FIELD
Script: Command
Library: C:\\Siemens\\Automation\\WinCC_OA\\KAIA\\scripts\\libs\\ptnavi.ctl
Line: 450, ptnavi_navigation, 30
Stacktrace:
1: ptnavi_DetermineSumAlertName(string strServerName = "System1") at ptnavi.ctl:450
2: ptnavi_DetermineDerivedTopoVariables() at ptnavi.ctl:434
3: ptnavi_InitializeAfterLogin() at ptnavi.ctl:174
4: afterLogin(string user = "root", string password = "", string newLocale = "", int closeModules = 2, int iConfNum = 1) at login.ctl:171
5: logincheck(bool bTriggerLoginOfUisOnComputer = FALSE, int extendedMode = 0) at login_internal.ctc:878
6: openUi() at [Module: Startup Panel: vision\\login.pnl ScopeLib: login.pnl]:96
7: main() at [Module: Startup Panel: vision\\login.pnl Object: password Script: Command]:17
schneebergera
Re: Runtime error
Post by schneebergera »
please start panel topology again via GEDI and check if there is a template assigned. Please export the data to a text-file.
Could you add a new WCCOAui in console (-p vision/login.pnl) and start the session?
regards,
IBRAHIMALALI
Re: Runtime error
Yes Andreas , I have done this without result
schneebergera
Re: Runtime error
But you are using self-made libraries (like"\\KAIA\\scripts\\libs\\ptnavi.ctl").
I would suggest to use default library (ptnavi.ctl), located in .
best regards,
IBRAHIMALALI
Re: Runtime error
changed it , but that didn't solve the problem , this is the logger again
WCCOAui (1), 2017.12.07 15:57:08.603, CTRL, SEVERE, 176, Uncaught exception in thread started at main:
WCCOAui (1), 2017.12.07 15:57:08.603, CTRL, SEVERE, 79, Index out of range,
Module: Startup
Script: Command
Library: C:\\Siemens\\Automation\\WinCC_OA\\3.15\\scripts\\libs\\ptnavi.ctl
Line: 450, ptnavi_navigation, 6
Stacktrace:
4: afterLogin(string user = "root", string password = "", string newLocale = "", int closeModules = 2, int iConfNum = 3) at login.ctl:171
Re: Runtime error
The log information describes that some dyn arrays for the panel topology in the mapping ptnavi_navigation do not fit together and therefore a specific index cannot be found.
The information for the mapping is read from the datapoint used for the topology.
The problem can maybe be solved by recreating the topology information.
