How to Link Alter panel to Alert Handling assinged in PARA.
Chandan
Post by Chandan »
Hi Experts,
I am new to WinccOA OA and facing problem with linking the alert panel screen to the
alert handling assigned in PARA.
I have added Alert Hdl in PARA as power configuration for the tags in PARA.
When I simulate the values I get the Alarms on the main panel/faceplate of the tags
but cannot get that alarms on the Alert Panel.
Can anyone help me with this.
Thanks and Regards
Chandan.
adaneau
Re: How to Link Alter panel to Alert Handling assinged in PARA.
Post by adaneau »
Talking about powerconfig, I guess you used master DP. This shouldnt be used directly, you need then to create DP derivating from master DP and parameterize locally.
Some tips:
- don't forget to check activate alarms on your dpe
- click on play when you open aes panel because it doesnt refresh table at opening
- check your filters (afaik if your alarms are below prio 10, they could not be visible by default)
Hope it will help you
Chandan
Post by Chandan »
Thanks for the reply.
The suggestions given by you was useful and now the
alarms are coming to the AES screen.
Chandan.
