sorting datapoints in para
IBRAHIMALALI
Post by IBRAHIMALALI »
Good day,
I want to ask if there is an organizational way to sort the data points in Para such that I have a hierarchy of devices . To explain more I have 7 ahus that contains nearly the same components they differ by one or two data points , is there a way not to make datapoint types for each one of them .
Regards
Re: sorting datapoints in para
The datapoints are sorted in alphabetical order for every datapoint type.
Also the datapoint types are sorted in the same way.
In WinCC OA you have datapoint types. A datapoint type defines the structure of nodes and leafs, both of them are called elements.
A datapoint is an instance of a datapoint type. At the elements you have some predefined configs and you can add configs, e.g. _address.
Based on this information please describe again what you want to do.
If you want to build a logical structure you can maybe use the Plant Model Editor (CNS). For details please have a look at the WinCC OA documentation: Special functions --> Common Name Service.
IBRAHIMALALI
I Think you didn't get me right , what I want is to make a folder to contain multiple data point types , to organize the para.
adaneau
Post by adaneau »
Maybe CNS no? Have a look onto plant model editor ;)
IBRAHIMALALI
Thanks for the help , is there any document that describes the plant model editor in more details than the help as I lack information in this topic , it would be appreciated
Regards
adaneau
Post by adaneau »
The section Common Name Service from Special functions in help is quite enough imho. Afaik I dont think there is something else available. Maybe you can ask support for some demo project....
