Export multilateral PDF
OlliAutefa
Post by OlliAutefa »
Hey everybody,
I designed a Panel with the size (1000x5000) to show some facts i have calculated.
Is it possible to Export the Panel to a multilateral PDF with the print in silent mode? I just get the wohle Panel minimized in one side.
Oliver
Re: Export multilateral PDF
Oliver Muehlberger wrote:
Hey everybody,
Oliver
you can print the panel with a pdf printer silently, switch the language and print again
printPanel();
delay(1);
switchLang();
delay(2);
printPanel();
ad "with a pdf printer":
you can export (print) any panel directly to a pdf file. This is a built in feature. There is no need for some external "pdf printer" software.
Simply use a file url with pdf extension as printer target on the _Ui_x.Print.PrinterName DPE
See qthelp://wincc_oa/doc/ControlE_R/printPanel.htm
A single panel file can only be printed onto a single page. There is no direct multi-page support for panels to print.
