the following information needs to be taken into account when using a project with RDB archiving.
The ASCII file included in patch 3.15 P007 is not complete and does not contain the updated _RDBArchive datapoint type.
If you are using RDB archiving the following log message will occur during startup if the dp type structure is not correct:
WCCILdata (0), 2017.11.29 09:08:10.638, PARAM,SEVERE, 8, Element does not exist, problem during archive initialization, datapoint does not exist:, .dbConnection.setPreferredHost:_original.._value
Enclosed you will find an ASCII file with the corrected structure of the datapoint type _RDBArchive.
Please make an ASCII import of this file and restart the project to get rid of the problem. The option to modify existing datapoint types must be set.
Sorry for the inconvenience!
With the next patch for WinCC OA 3.15 the files will be corrected.
Senior Support Specialist https://www.winccoa.com/fileadmin/image ... rchive.txt
DP element is missing for _RDBArchive datapoint after applying patch 3.15 P007
- Attachments
- update_RDBArchive.txt
- (847 Bytes) Downloaded 358 times
