Qt Widget: how to send message to PVSS log from Qt Widget (qDebug()??)
sblancha
Post by sblancha »
How to use qDebug in Qt widget development.
I try different statement according to qDebug qt help but always get the following weird message in PVSS log:
WCCOAui (1), 2017.11.29 11:13:37.670, CTRL, INFO, 0, , îþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþîþkþ>$?b0¨º+Q
Cheers,
Sebastien
Re: Qt Widget: how to send message to PVSS log from Qt Widget (qDebug()??)
When you use qDebug() you should not see a message like this, since qDebug()s are redirected into the managers log file and not using the ErrHdl,
therefore not having this format you show (e.g. having timestamp, CTRL or INFO in it.)
When you use QDebug with e.g. QtInfoMsg, then the UI always generates a SYSTEM type message and the message id is "Unexpected state".
Therefore, please share more details, e.g. your code snippet
sblancha
Post by sblancha »
Thanks Martin for the fast answer.
I am using now Qt5 and WinCC OA 3.15.
I tried many statements, for instance:
qDebug()
I tried this just to be sure (3.15, Linux openSuse) - no problem.
qDebug()
sblancha
Post by sblancha »
I did not try with Linux
but with 3.15 Windows10:
qDebug()
