How to change format time in Trend?
zheleschikovav
Post by zheleschikovav »
Good day!
How can we change format time in trends from "11/28/2017 10:32:37" AM ?? "28.11.2018 10:32:37"?
see attachment. Image
nmnogueira
Re: How to change format time in Trend?
Post by nmnogueira »
Have you tried changing the time format in the trend parametrization?
zheleschikovav
This help only under ruler format time format, but usless for others place(see attach 1,2). Image
With 3.15 SP6 the ruler window is a real panel, so you can adapt your case (1) as you like. Check trendRulerPanel.pnl
The format used in your case (2, dat/time displayed at the ruler inside the plot area) is hardcoded to use the locale information according to the projects current language
(so it uses %x and %X).
zheleschikovav
lang=en_US - can't be changed
WinCC OA 3.14 patch 014
and format time need "28.11.2018 10:32:37"
In WinCC OA 3.14 you cannot change the time format for the trend ruler popup.
As Martin Koller has written the trend is using the hardcoded formats "%x" for the date and "%X" for the time.
It probably will work if you change the settings in the operating system how the date/time shall be displayed for a specific locale.
Note: All applications running on this computer will probably be affected.
