Script Editor for Grapical Object\'s Extended Events Obfuscates Extra Code
ChristianGoehring
Post by ChristianGoehring »
Within the Script for an Graphical Object's Extended Events (for example, the WebView ewo's "urlChanged" event), any extra code besides the function (for example a #uses directive or enum declaration) is removed by the Script Editor.
I am using WinCC 3.15 P05 on Win 7. You can recreate this behaviour by the following steps:
1. Create a new panel
2. Place a Webview Ewo within the panel
3. Within the properties window, open "extended"
4. Within the "events" section of the window, click on "Open Script Editor" for the "urlChanged" event
5. Paste the following code:
enum TestEnum
  Value1, Value2
urlChanged(string url)
  DebugTN("Does it still exist? " + (int)TestEnum::Value1);
6. Save the script and close the Script Editor
7. Open the script for this event again
The following code is now within the script:
  Value1, Value2
- There is different behaviour for different declarations or directives before the function
- Within the standard events with main-method, it does not obfuscate or delete code
Re: Script Editor for Grapical Object\'s Extended Events Obfuscates Extra Code
Obviously a bug.
In general the "extended" scripts do not allow to keep anything else but the code of the given function.
