LS,
WinCC-OA 3.15
Windows-7 SP1
In my application i like to read some configuration settings from configfile named "config_subsystem" which is located in the \\config directory.
To resolve the path of the config file I use
string sPath = getPath(CONFIG_REL_PATH,"config_subsystem");
I checked the file is in the directory!
Running this line of code on a normal UI then then sPath gets filled with the absolute path as expected.
Running this line of code from a Desktop-UI (on the same machine) which is connected to the project then sPath stay's empty.
I can't figure out what i'm missing here!
- Do i have to do an additional settings when running a Desktop-UI which is connected to a project running on the same machine?
- Does getPath have difficulties getting filenames from the config directory?
Michel.
getPath() on Desktop UI returns an empty string
- michel.eijgermans
Re: getPath() on Desktop UI returns an empty string
The config directory is 'protected', files in this directory by default cannot by downloaded (by getPath). You would need to add a 'httpConnect' for these files.
Or move your files to for example to the data directory.
- michel.eijgermans
Gertjan, thx.
Then it makes sense that Stylesheet_dark/light isn't loaded as well
- kilianvp
just name it "stylesheet.css" and your stylesheet will work!
they bypass the security by doing
in webclient_http.ctl.
If it wont work for you dont have the lastest 3.15 Patch
httpConnect("getTouchStyleSheet", "/config/touchscreen.css", "text/plain");
