Maintenance?
Re: Maintenance?
Due to maintenance reasons the ETM Portal was offline for a few days, now it is back online.
We apologize for the circumstances!
- ewoenne
Re: Maintenance?
It looks like some recent posts are not appearing on the forum. The link from the notification email below now goes to a different topic!
A new post has been made to a topic to which you have subscribed on the ETM Portal Forum
Subject : Re: Redundant distributed system managers
Forum : Bugs / Problems
Posted by : Leopold Knipp
You can administer your subscriptions by following the 'My Profile' link on the Forum home page after you have logged in on the site. From your profile you can also unsubscribe from the topic.
URL: https://portal.etm.at/index.php?option= ... =6846#6852
Message:
The starting order described in the documenation is correct as it refers to a server project.
A user interface is normally not part of the server project in a real application, e.g. if the server project as a service the UI cannot be started as no user is logged on when the project startup is made.
The control manager listed before the redundancy manager is the manager using the pvss_scripts.lst script list.
You cannot ensure that the drivers have received current data before the ctrl managers are started and initialized if the drivers need longer to establish the connection to all peripheral devices than the ctrl managers need to start.
Therefore starting the drivers before the CTRL managers is not really necessary.
The proxy manager is only used for inbound connections from a different host then the own. In standard configuration it is started after the Event Manager to allow connection to the server when the core processes are started.
Message:
- nmnogueira
Re: Maintenance?
I am having the same problem with a topic I had created.
Subject : Re: Alert status for Sumalerts Forum : Bugs / Problems Posted by : Leopold Knipp
URL: https://portal.etm.at/index.php?option= ... =6847#6853
Message:
This is the newest patch for WinCC OA 3.14.
Can you reproduce the behaviour?
If this is possible please describe what alert is changed in which way to get the described behaviour.
Message:
