The log message describes that the limit for storing the last values have been reached, at least on record type has reached the limit.
For every record type (e.g. bit variable, float variable, ...) in the RAIMA database there is a limit of 16.777.216 records.
How many records of which type are needed to store the information depends on the datatype and the amount of data.
There is no fixed limit defined in the database. Which amount of data can be saved additionaly depends on how much data is already saved.
Storing a given amount of data will probably work in one project and not in another one if there are more records already used.
Why do you want to store a blob of 429MB?
Is it necessary to store it in the database or do you just need the information during runtime?
If there is no need to store it persistently in the database you can deactivate the last value storage for this dp element.
With a blob there is no need to encode it. You could read a file directly in a blob with 'blobRead'.
With the base64 encoding you could also store it in a (dyn_)string.
