Oppress Warning Message
OlliAutefa
Post by OlliAutefa »
I want to work with the function "openAES()". In the script of the button i defined the function like:
string screenConfig, module, fileName;
int action = 2;
screenConfig = "test";
module = "WinCC_OA-AES";
fileName = "aes";
openAES(screenConfig, module, action, fileName);
While running the Quicktest the screen opens but Shows the message "You want to get 2621 DPEs (max 2000). This can last a Long time. Do you want to start?".
1.) Is it possible to set the max.-Value higher so the message does not appear?
2.) In the screenConfig i defined a closed period of time but the function doesn't print me the file "aes". I just have to put the Name and Type in the saving-screen. Why?
Oliver
Re: Oppress Warning Message
In the panel System Management --> Settings --> Central Settings you can define limits used in the AEScreen.
For details please have a look at the WinCC OA Documentation for this panel.
Can you please describe it more detailed.
Which file shall be printed?
What is a "saving-screen"?
OlliAutefa
Thanks for your reply.
I just want to Export the table of faults every day. So i defined the screenConfig "test" with the property "Range of Time: closed and yesterday".
When I start the Script in the Quicktest the AES opens but not with the actual list of alerts. The list is empty. I just have to click start/refresh to get the alerts in the table from yesterday. In addition there is no file printed/safed in the /data-folder.
I expect to get the safed/printed fault-table of yesterday when I click a button or later with a script.
I hope it is more comprehensible now and you can help me with this Problem.
Oliver
