I am trying to use WinCC OA video feature, but when I start Video Manager, I get following messages in log:
WCCOAvideoOA (1), 2017.10.23 11:59:31.909, PARAM,SEVERE, 1002/voa_general, , VimaccControlSocket, exceptionRaised, localhost, 127.0.0.1
WCCOAvideoOA (1), 2017.10.23 11:59:35.910, SYS, SEVERE, 1025/voa_general, , VideoManager, handleLicenseState
WCCOAvideoOA (1), 2017.10.23 11:59:40.914, SYS, SEVERE, 1015/voa_general, , VideoManager, handleConfigState
I supose that the problem is related with video license, but you told us that it is possible to run WinCC OA video for 8 hours in demo without a video license. I copied files LicenseFeatures.opt and LicenseFeatures.sgn from folder C:\\vimacc\\data\\features\\license to C:\\Siemens\\Automation\\WinCC_OA\\3.15, but these errors are still here. Also, when I start Video Object Explorer, there is no normal tree in menu. Instead, i there are only messages "voa_general not found" (image in attachment). I supose those two problems are related.
Thanks,
Nedžad
WinCC OA video - licensing
Re: WinCC OA video - licensing
Could you share your solution to this problem? It could be helpful if someone else has the same problem.
- nedzad
It was just about copying files from C:\\Siemens\\Automation\\WinCC_OA\\3.15\\Video_3.15\\msg folder to \\msg folder
