Hello
I've developed a Qt Widget that connects to a CCTV Software and gets the video of the cameras registered in this software, I tested this widget in a WinCC OA Client - Server architecture in a Remote UI but it crashes and closes in the Client, when i mount my widget in the Server, it works well ¿What can be the cause of this? My widget is decoded with a C++ dll library, ¿Is it possible that the widget is not compatible with the remote UI?
Bug Widget with Remote UI
Re: Bug Widget with Remote UI
If your ewo needs an external dll for decoding but this is not installed on the remote client machine, then the UI will crash since it does not find the required library
- jeissonsierrac
Hello
Thanks for your support.
I copied all the libraries in the bin directory of the Wincc OA installation path of the remote client PC, this works for a while but then it crashes, when I run the Widget on the server, it works fine. What other problem could it be?
Without any error message, stack, etc. this is impossible to say.
Note that your external libraries must be located in a path which is searched by the operaing system(!) (PATH env var on windoze), since it's the OS which searches dependencies - not our UI
The remote UI is the same UI as on the server, so if the external libraries are available it should be exactly the same.
The EWO is not loaded by the UI, if it is linked against an external library, which is not found/accessible for the UI. So it should not crash.
