GisViewer Mobile UI Compatible
uxout
Post by uxout »
I would like to use the GisViewer via Mobile UI but this widget seems to not be layout compatible.
Is there a way to make it compatible or to use it correctly with Mobile UI?
Re: GisViewer Mobile UI Compatible
Could you explain what is wrong? And post a screenshot of it?
uxout
Post by uxout »
Finally it's fine. You can close this thread, thanks.
Could you share how you have fixed this problem? It could be helpful if someone else has the same problem.
uxout
Post by uxout »
Well just avoid to use Layout with the GisViewer and use it in module instead.
I hope this can help someone.
