What is a typical Call back up time for Wincc OA server When wincc OA server starts to recognize IP address of all RTUs?
Pradip
Re: Call back up time for Wincc OA server
Hello Mr. Pradip Mohod,
a typical time for the startup of a project is not available because there are a lot of factors influencing the startup time:
-- installed hardware (CPU, harddisc, memory)
-- used PVSS-/WinCC OA-version
-- operating system
-- configuration of the project (single, redundant, number of processes started during startup)
-- "size" of the project: number of datapoints, number of dp-elements, configuration of the configs (alert-handling, archiving, dp-functions, ...)
-- driver-configuration (number of drivers, number of connected RTUs, number of addresses)
If you want to get the startup time for a project in your configuration you have to make some startup tests measuring the time.
Maybe the configuration can be optimized to reduce the startup time.
Please refer to the common WinCC OA-support (support.automation@siemens.com) if you have additional questions.
-- operating system
- mweber
Hello Pradip,
could you please explain in detail what you are thinking of when asking for the "typical Call back up time".
I am not sure if you were refering to project start up time (I dont think so).
Maybe we could help you if we know exactly what you are trying to achieve.
best regards
Markus
best regards
Markus
