hello,
I'm trying to use function RootpanelonModule an I have a little problem.
I use following script:
main()
{ RootPanelOnModule ("fileName", "PanelName", "ModuleName_1", "")
I've got 4-screen workstation and I don't know what parameter should I use in ModuleName to display screen on current monitor, because if ModuleName have parameter 1 it doesn't matter on which monitor (1 or 2 or 3 or 4) I click button it always open on monitor 1.
thanks
Michal
screen number
Re: screen number
If a panel shall be opened in a specific module you have to address the correct module.
Where is the object located which shall open the panel on the same monitor?
Are you using one of the panel topology templates?
Senior Support Specialsit
- mku
Re: screen number
I created my own template that has basePanel, infoPanel and NaviPanel. In basePanel there are 3 widgets (infoModule, mainModule and naviModule). In naviPanel I created push_button with function like I wrore previously. With this buton I want to open new panel (root). When i click this buton on monitor 1 new panel should open in monitor1, when I clic on monitor 2 new panel should open on monitor 2 etc.
best regards
Michal
best regards
Michal
Re: screen number
In the standard templates the (screen)-number is passed to the base panel using a $-parameter.
The same $-parameter is then used to assign a unique module name to the embedded modules.
If you are using a similar concept you can use the $-parameter to get the information which screen the script is started on.
Re: screen number
Michal Kurowski wrote:
If you use the same naming convention for the module names as the standard templates (suffix them with '_' and the screen id), you could this:RootPanelOnModule ("fileName", "PanelName", "ModuleName_1", "")
RootPanelOnModule ("fileName", "PanelName", "ModuleName_" + ptnavi_GetScreenName(), "")- mku
Re: screen number
Gertjan van Schijndel wrote:
thank you very much.
best regards
Micha?
great, it works.Michal Kurowski wrote:If you use the same naming convention for the module names as the standard templates (suffix them with '_' and the screen id), you could this:RootPanelOnModule ("fileName", "PanelName", "ModuleName_1", "")Code: Select all
best regards
Micha?
- mku
Re: screen number
hello,
As I wrote it works but only once. When I click buton panel opens but if I try to open another panel via another buton there is no reaction (nothing happens) and log is empty.
When I try to open different panel via buton which is configured via panel topology it works and after that i can open panel via buton but only once, after that another buttons doesn't worlks (only buttons from panel topology works)
best regards
Michal
best regards
Michal
Re: screen number
If a different panel shall be loaded in the same module you have to use a different panel name.
Maybe the panel name used in the function to load the panel is always the same and therefore it does not work.
- mku
Re: screen number
hello,
It was my mistake, I was using the same panel name.
Now it works.
thank you
best regards
Michal
Now it works.
thank you
best regards
Michal
