How monitoring CPU and HDD usage?
senchenkov_n
Post by senchenkov_n »
Hi guys!
Help describes the standard way to monitor RAM usage, but cannot do it for CPU and HDD.
How can I solve this problem?
Re: How monitoring CPU and HDD usage?
To monitor the disc usage you can use the disk space check functionality of WinCC OA.
For further information please have a look at the WinCC OA documentation: System Management --> Diagnostics --> Disc space/RAM space.
To trace the CPU usage there is no standard functionality available in WinCC OA.
If you want to get this information on a Windows system without the possibility to have the data available in WinCC OA you can use the Windows Performance Monitor. An explanation how to configure the tool you can find in the FAQs:
In another thread you can find a toolkit which can be used to trace the CPU- and memory usage:
https://portal.etm.at/index.php?option= ... id=14#1326
Please note that this toolkit is officially not supported.
