How to Sum the total number of unacknowledged alarms?
7 posts • Page 1 of 1
vince2e
Post by vince2e »
Hello all,
I'm trying to count the total number of active and unacknowledged alarms. I can generate the list of alarms in the Alarm Screen, but I can't seem to figure out how to Query the Raima DB for the alarm history in my scripts. Is there a specific config that I could do a dpQuery or dpGet on?
vince2e
Re: How to Sum the total number of unacknowledged alarms?
Post by vince2e »
Forget the question above. I was able to figure it out with help from the SQL query builder & the help manual.
Here are the scripts I'm using to get alert info.
//Historical Alert Info
//string query = "SELECT ALERT '_alert_hdl.._(ENTER CONFIG)' FROM '(ENTER DP_NAME)'";
string query = "SELECT ALERT '_alert_hdl.._value', '_alert_hdl.._prior', '_alert_hdl.._text', '_alert_hdl.._act_text' FROM 'F-1504'";
dpQuery(query, Result);
DebugN(Result);
//Current Alert Info
dpGet("System1:F-1504.Temperature.HiTemp.Status.L1:_alert_hdl.._act_state", Test3);
DebugN("This is the alert State "+Test3);
If you want to get only the alerts which can be acknowledged you can extend the query with a WHERE condition.
E.g. you can use the attribute _ackable in the condition WHERE '_alert_hdl.._ackable' == 1
vince2e
Post by vince2e »
Thanks Leopold,
That is a good option. Is there anyway I could filter all of my DPEs under a system name? Currently, I have to use multiple patterns such as "System1:*.*:_alert_hdl" or "System1:*.*.*:_alert_hdl". I would like to use something more generic like as "System1:*_alert_hdl", but that doesn't work.
If you want to filter data for a specific system name you have to use the REMOTE keyword.
Using the systemname in the SELECT or FROM statement is not supported.
For detailed information please have a look at the WinCC OA documentation: System management --> Reporting --> SQL.
You can use the pattern '*.**' to get all datapoint elements in a system.
If you want to get all dp elements for a system in a query the FROM clause can be '*'.
There is no need to add another or different wildcard pattern.
