• Page 1 of 1
ask
Adding \"_general\" config to dp
Postby ask »
I need to use _general config in large number of dp.
I can add this config only when dp is "simple" = without master dp.
I cannot configure it for master dp - this config is not accessible.
Why?
How to add this config for a number of dp's?
Right now the _general config cannot be used as a power config on master datapoints and the instances.
If you want to add the config to a lot of datapoint you can
-- prepare an ASCII file which adds the information
-- write your own script which adds the config and writes the required values
With a dpSet() you can add and configure a config.
Which attributes need to be set you can see when doing an ASCII export for an already configured config.
