Hello
I am trying to get information from an API that uses HTTPS via JSON using the "netGet" function, but I can not connect, this function returns me that there is no connection and when I debug the resulting header always shows me this value in the variable errorString "Error while reading: error: 14094410: SSL routines: SSL3_READ_BYTES: sslv3 alert handshake failure, error: 140940E5: SSL routines: SSL3_READ_BYTES: ssl handshake failure"
I take as an example the code found in the documentation in the function JsonEncode and also install all the certificates needed to access.
PS: When I call it in Chrome and Internet Explorer, this works.
netGet JSON function
- agruber
Re: netGet JSON function
Eventually the handshake cannot be made because the CA cert store does not have a valid CA certificate for the site you want to connect.
Eventually a new cacert.pem file helps, it needs to be copied to the WinCC OA config directory.
More info about this file and where to obtain it can be found here:
https://stackoverflow.com/questions/149 ... rt-pem-for
BR,
Customer Care
BR,
Customer Care
- jeissonsierrac
Hello
Our supplier sent us the file file *.pem. We copied it in the folder C:\\Siemens\\Automation\\WinCC_OA\\3.14\\config
Our supplier sent us also the file file *.p12 that we imported in our windows 7 system.
our script is :
The function return in the log file what we posted previously.
Our understandigs is that the WinCC OA doesnt use this certifacete.
Any tips?
our script is :
mapping options;
options["ignoreSslErrors"] = makeDynString("");
iAnswer = netGet("https://internetAddress, result,options);
delay(0,1000);
if ( iAnswer == -1 )
DebugN("error of the netGet Function",result);
dpSet(sDPError,1);
else
dpSet(sDPError,0);
DebugN("result as value",result);
Any tips?
- rgreino
Dear DJ Sierra, Andreas,
It would look like net* functions do not provide a way to set the client cerfiticate/key (or it is at least not documented).
As example, equivalent of :
QSslConfiguration::setPrivateKey
QSslConfiguration::setLocalCertificate
QNetworkRequest::setSslConfiguration
It seems like Control doesn't expose this interface or it is not documented.
Bobby
Bobby
