I want to have information alerts without acknowledgement, like:
The engine MTR1 is ON
The engine MTR2 is OFF
The valve VLV5 is OPENED
... etc.
I don't want them to be seen in the notification panel at the top of the screen (alarm row), but only in the big AEScreen panel. How do I do this?
Info alerts
Re: Info alerts
The easiest solution is to use specific priorities (e.g. low priorities) for the information alerts and to filter for the priorities in the AESRow and the AEScreen.
With the $-parameter $SCREENTYPE you can define a AES configuration which shall be used in the AESRow. At this configuration you can define the filter settings which shall be used.
- twinsen
Re: Info alerts
Thanks, Leopold! That did the trick. I'm now able to filter shown alerts by their priority. One more question about AESRow:
Rather than clicking each alert, is it possible to add a button that will acknowledge all visible unacknowledged alerts in the AESRow panel?
- nmnogueira
Re: Info alerts
There's a global ackonowledge button in the AEScreen, so you can check the code of the button there and try to use it in the AESRow.
Re: Info alerts
The common confirm button in the AEScreen only acknowledges the alerts which are visible at the moment.
If an alert is shown in a table line which is currently not visible this alert is not acknowledged.
This is made on purpose to avoid that a user acknowledges an alert which is not visible at the moment.
