[OPC Communication] I want to use OPC DA and OPC HDA using same name.
dongil
Post by dongil »
HI..
I have some problem about the opc communication..
Our OPC client system can get data from both opc da and opc hda.
But I cannot get data from WinCC OA Server , because of the tag name.
opc da and opc hda are work, Separately .
When i see opc data using opc da. if DPE name is AA.value.PVLAST. and DP type is GROUP_A
I can see "WinCC_OA.AA.value.PVLAST"
When i see opc data using opc hda. if DPE name is AA.value.PVLAST. and DP type is GROUP_A
I can see "GROUP_A.AA.value.PVLAST"
Can I have the same tag name whenever I use opc da and opc hda ?
-- Can I change from WinCC OA. to GROUP_A. for opc da?
-- Can I chagne from GROUP_A. to WinCC_OA. for opc hda?
Please reply ASAP.
Re: [OPC Communication] I want to use OPC DA and OPC HDA using same name.
The root node for the OPC DA server can be set with the config entry:
[opcsrv]
rootNode = "GROUP_A"
dongil
Post by dongil »
[opchda]
rootNode ="WinCC_OA"
Is it also work? because there are so many DP type name on the server ..
You can also use the DP type as root node with the OPC DA server with the config entries:
[opcsrv]
rootNode = ""
showDPTs = 1
BTW: The name for the OPC HDA server section is 'opchdasrv'.
