After that, i added the _address config for all the DPE's and its working fine except for two of them all. When i get to the S7+ symbolic address panel, where the exported project from TIA Portal is shown, i miss these 2 variables.
Left - S7+ symbolic from WinCC OA//Right - TIA Portal
(I know it is an English forum so please ignore the name before the _C*number*, they are meant to be grouped as 8)
Notice that in the first case i am losing the 'xxxxxxx_C4' variable, meanwhile in the next one i am losing the 'xxxxxxx_C7' variable.*Couldn't upload both cases because of the size*
However, they actually are on the TIA Project. I am not sure if they would work if i just write the reference myself.
These 2 variables are just identical to the others around them, same type, configuration, visible on the hmi and everything.
I tried to export the project a couple of times, modifying those variables, creating them again but i get the same result.
I think it is a bug and i wanted to know if it happened to someone else or there is something truly evident i am not doing right.
Thank you for your time.
Agustín Romero.
