How to import master datapoints with ASCII manager ? V315P005
amichon
Post by amichon »
I need to change configuration of the master datapoint (add alert handling, archive, ...) and save/reimport/apply updates with Ascii manager.
Ascii manager does that but at the end of importation it's not possible to change Power Config with PARA on DPE level. It's only possible to insert Power Config (see file attached)
Re: How to import master datapoints with ASCII manager ? V315P005
If you want to transfer information for a master datapoint _mp_ into another project you have to export the master datapoint and its configs. Also the information stored in the original values of the datapoint _dt_ must be exported and imported.
Otherwise the information is lost which powerconfigs are configured.
Please check which data you have exported and imported.
In the ASCII manager panel you have an option where you can select if also the power config information shall be exported ("Pwr. Conf. Settgs").
amichon
Post by amichon »
It works perfectly. I had forgotten to export the internal DP _dt_.
Thanks a lot.
