• Page 1 of 1
v3gard
Possible to set custom property with setValue?
Postby v3gard »
The subject really says it all. I have a panel called P, with a property called "eventReference". In GEDI, I can add a panel reference to panel P, and set the property manually in the property window, which works as intended. I can also change it in control (e.g. in the root panel's initialize function) by running P.setEventReference("someValue");
However, I would like to run the "setEventReference" function dynamically using setValue in the root panel (where the panel reference is). I am running this:
