Reading WinCC OA Version and Patch number
RudiKreiner
Post by RudiKreiner »
I stumbled over the predefined symbolical constants VERSION and VERSION_DISP in the Online Help Function recently and decided to use them right away to display this information in our UI for diagnostics purposes.
It would be nice to have a constant for the patch level too.
Is there any way of accessing that?
Re: Reading WinCC OA Version and Patch number
I total agree but you can make your own const
string getPatch()
  dyn_string dsReadmes = getFileNames(WINCCOA_PATH,"ReadmeP*.txt");
  string sReadmeFile = "ReadmeP";
  string sText = ".txt";
  string sZero = "0";
  if ( dynlen(dsReadmes) )
    this.visible = true;
    dynSort(dsReadmes, true);
    for ( int i = 1; i
schneebergera
Post by schneebergera »
it's possible to check the version incl. patch-level via the mentioned code (about.pnl).
There is no constant for the patch-level existing.
The control constant "VERSION_DISP" shows not only the version but also the "service pack number" (eg. WinCC_OA 3.11).
Nowadays, we don't count on "service packs". So version "3.15" is correct because we implemented no "service pack" so far.
best regards,
Since 3.15 there is the new CTRL function getVersionInfo() with which you can get all sorts of version information
schneebergera
good to know :)
please refer to WinCC_OA Help (3.15):
[CONTROL - Control functions - getVersionInfo()]
Description:
The function returns the current version information of WinCC OA.
The return values depend on the used key value and can be used to e.g. distinguish between patch, version (major or minor) or used platform.
RudiKreiner
Super, thanks for the info.
