openUrl() is not defined when calling from WCCOACtrl
LIGO
Post by LIGO »
Hello.
I faced a strange problem, when I'm trying to open a browser window from separate Ctrl manager (via std_help). That error appears:
WCCOActrl (3), 2017.07.21 10:38:41.620, CTRL, SEVERE, 72, Function not defined, backResRep.ctl Library: C:\\Siemens\\Automation\\WinCC_OA\\3.14\\scripts\\libs\\std.ctl
Line: 250, openUrl
It looks like some library is not included in that manager, but I can't find which one is missing. May someone guide me where to find it, or is it even possible to use that function from Ctrl manager?
Re: openUrl() is not defined when calling from WCCOACtrl
openUrl() is only available in the UI manager
you can use
system("start https://www.google.com/");
to open the url in your default browsers
LIGO
Post by LIGO »
Thank you very much, Kilian.
That is just what i needed and it works perfectly.
