What data types can be a member of a structure or class?
- tgdannemiller
I've created a structure, and one of the members is a mixed type. There are no errors, but when I create an instance of the structure and assign a value to the mixed type member, it always reads back as empty or no value. I also tried an anytype member with the same results. Are there restrictions on what data types can be used as members of a structure? I looked in the help but couldn't find anything addressing that topic.
Re: What data types can be a member of a structure or class?
That's a bug. I could reproduce it and will create a bug tracker entry
- ozangor
In addition to that, it is not possible to use a class as a member of its own.
class MyClass()
MyClass obj;
}- mkoller
Correct, you can't have your complete own class inside your own class ... but I assume that is not what you really want.
Maybe you are thinking just about a _pointer_ to your own class, e.g. the following works:
class Node
public shared_ptr next;
main()
shared_ptr root = new Node;
root.next = new Node;
root.next.next = new Node;
DebugN(root);
